Author Topic: Cal Spa Jet Replacement  (Read 2235 times)
tresguey
« on: August 27, 2013, 03:02:25 pm »
Hi, new here. I just picked up a used Cal Spa and it has a couple jets that I want to replace. They are the spinning type with two jets on either side. They are not spinning. Does anyone know how hard they are to replace? Do I need to drain the Spa?
Re: Cal Spa Jet Replacement
« Reply #1 on: August 27, 2013, 04:35:24 pm »
  Simple waterway jets, you can twist the jet counter clockwise and pull while twisting it should come out.  Or you can twist it and use a butter knife behind the edge of the jet face and pry a bit.  You can find many online sources for waterway jets.     When you put the jet back in, on the back of the jet is a little square psc that needs to line up with the groove on the jet back (part in the spa the jet goes into) just push it in till it snaps.   should rotate left and right a half turn or so each way.
