Author Topic: Leaking manifold Jacuzzi J-355  (Read 4933 times)
dennisoates
« on: August 04, 2013, 02:40:40 pm »
The leak is at the blue line  more towards the center of the pic ,at a coupling. How do I remove this and repair this major leak, it is from ice damage I think. It is packed with foam and I removed quite a bit. Do I have to cut a hole in bottom of the base to access this area,?  This is on the manifold and there are 8 lines attached to this and its a tight area. any tips or suggestions would be appreciead.
http://www.flickr.com/x/t/0095009/photos/rainbowtawas/9438083570/
« Last Edit: August 04, 2013, 02:47:23 pm by dennisoates »
Re: Leaking manifold Jacuzzi J-355
« Reply #1 on: August 04, 2013, 03:41:46 pm »
      Your tubs only 2 years old why don't you call your dealer, and you seem to be the original owner, not bought from some lady??
TwinCitiesHotSpring
« Reply #2 on: August 04, 2013, 03:53:31 pm »
if it is in fact at the coupling on what appears to be rigid pipe its going to be a severe pain in the you know what...you going to have to dig it back as far as possible and cut it with probably a "wire saw" in order to fit new couplings and a piece of flex pipe in there
dennisoates
« Reply #3 on: August 04, 2013, 03:58:53 pm »
ice damage is not covered by warranty Jim
« Reply #4 on: August 04, 2013, 06:45:31 pm »
  I'm not entirely sure you have freeze damage there.   Usually when/if  I see freeze damage it's at the pump housing/ pump unions or heater housing.  Not buried in foam at a manifold/connection.   And freeze damage is most times a big crack, not a drip, from a glue joint.
dennisoates
« Reply #5 on: August 04, 2013, 08:52:35 pm »
good point maybe they will warranty it, the pic don't show it , but the coupling is split /broke, all the way around
