Author Topic: hotspring sovereign1 heater problems  (Read 2066 times)
dcnr
« on: June 07, 2013, 10:14:31 pm »
2002 spa. Temperature is set at 100 degrees and went up to 115 after it was running for about a week. I am new at this. What is my problem. Thanks
dcnr
Re: hotspring sovereign1 heater problems
« Reply #1 on: June 08, 2013, 10:32:40 am »
The digital reading is 100. water temp is 115. thermostat? hi limit switch? both??
« Last Edit: June 08, 2013, 09:25:45 pm by dcnr »
Flyonthewall
« Reply #2 on: June 08, 2013, 07:31:00 pm »
replacing the thermostat and high limit thermistors is pretty easy and inexpensive if you want to try and avoid a service call.  the 2002 sovereign has the heater circuit board in its control box that has caused numerous heating issues.  i don't recall ever hearing it causing an overheat problem.  the thermistors seem the most logical cause to me, but wait to hear some other members chime in, as i am way closer to the grasshopper as opposed to the number of spa masters roaming this board during the work week.
