Author Topic: SD and Jacuzzi AND ABS Pans  (Read 4624 times)
dazedandconfused
  • Still Negotiating ....
« on: June 05, 2004, 10:01:42 pm »
Aren't these 2 spas made in the same factory in Chino, CA?
Does anyone have a phone # that goes to someone technical in the plant?
I want to know if I can buy one abs plastic pan (one that fits a Jacuzzi 375) and use it for a SD Cameo.  These 2 spas have identical measurements.
It would be great if I can use this Jacuzzi abs pan on my future SD Cameo for better moisture protection.
The customer service people at the main SD hone probably will not have the answer.  I need the number for someone in the plant in production.  ANy advice?
dpgtech
  • Jacuzzi Premium/Coleman / tech&deliverysp ecialist
Re: SD and Jacuzzi AND ABS Pans
« Reply #1 on: June 15, 2004, 12:02:30 am »
the sundance structure is not designed to accept the pan of the Jacuzzi outside dimensions may be the same but the structure is set up different. the factory would tell you to talk to your dealer, and normally does not deal directly with spa owners.  Ask your sundance dealer, but I have seen both manufactured and the pan is a main part of the jacuzzi design and would not fit on the SD. :)
