Author Topic: Tub throws FL code after every stop  (Read 2680 times)
Nordicuser
« on: May 30, 2013, 06:59:33 pm »
Newbie to the forum.  Have a '98 Nordic DLX with a balboa controller.  Every time the tub goes through a cycle it throws an FL code after the cycle is done.  I know this is a flow problem and have changed the filter and verified that everything is plugged in right and getting the right voltage.  Do I need to replace the board or is there something I'm missing?
Re: Tub throws FL code after every stop
« Reply #1 on: May 30, 2013, 08:17:10 pm »
I think on that tub you need to change out the board. Pretty sure the flow switch is built into the board.
Nordicuser
« Reply #2 on: May 31, 2013, 09:12:30 am »
I called around to balboa dealers no one can match up my part # 27100_P.  Any ideas?
« Reply #3 on: May 31, 2013, 05:55:24 pm »
Call 1-888-Get-Tubs and push 8 Rodney or Shawn will answer and if there are no Nordic dealers nearby they will sell you the part needed
