Author Topic: J-345 should circulation pump show some continuity?  (Read 4220 times)
bthompz
« on: May 28, 2013, 01:11:54 pm »
Hi there,
First off I'm a newbie for repairing hot tubs so bare with me.  I have a FL 1 error on my jacuzzi j345.  I checked the flow switch and it's fine.  I suspect the circulation pump is no good.  I pulled it out of the hot tub and drained the tub.  If I switch my multi-meter to continuity test and put it across this pump I get nothing.  Does this mean a winding has burnt through in pump? I suspect there should be some resistance in order to work.  When I do this test against the other 2 larger pumps they do show continuity.
could someone let me know if my thinking is correct?  I don't want to pay 300 bucks to find out my circ pump is good.
Thanks again,
Brad
« Last Edit: May 28, 2013, 01:15:22 pm by bthompz »
bthompz
Re: J-345 should circulation pump show some continuity?
« Reply #1 on: May 28, 2013, 02:05:41 pm »
i have been told that you won't get continuity on a circulation pump so that answers that I will have to try to power it up.
« Reply #2 on: May 29, 2013, 11:39:01 am »
So odd! I have tested circ pumps for continuity, and yes, I have measured resistance across the leads.
Powering it up is by far the best way to test it.
 8)
