Author Topic: Geo spa..(cal spa)  (Read 3299 times)
brillskill
Geo spa..(cal spa)
« on: May 13, 2013, 07:06:53 pm »
It's been 2 months and I have to give the geo spa excellent feed back..(keep in mind cost was $3200)..I would consider this tub in the lower end value category..how ever in my opinion it's at or near the top in this category....quiet ,several jets including foot jets,110 plug and play (220 optional),beautiful acrylic ,relatively string pump,diverter if you want "hydrotherapy",came with led lite,and can sit 5 comfortably.(says 6 but it would be very personal)..all in all so far so good!
Geo spa..(cal spa)
Re: Geo spa..(cal spa)
« Reply #1 on: May 13, 2013, 08:21:43 pm »
  Good deal, glad it's working out for you.     The Cals we had the least amount of trouble with were the simpler ones.  Std heater, std control pak, basically just not a lot of bells and whistles like many of their other models..     I suspect the jets may blow out at some point down the road, but they are readily available online.
brillskill
« Reply #2 on: May 13, 2013, 08:29:15 pm »
Thanks...also of course they raised the price on the geo to over $4000 for the season..in that price point for a little more I'd probably look at Nordic
« Reply #3 on: May 13, 2013, 09:38:56 pm »
Good deal. Glad you are enjoying it
« Reply #4 on: May 13, 2013, 10:19:05 pm »
Nordic prolly uses the same equipment, filtration jets and controls..  When you are looking at these types of spas, well I call them component spa's.  Not a bad thing but they are made for the masses, some are cheaper built than others, it why your able to buy that type of spa at the price you did, give or take what goes in them..   While Nordic may use the same components it is a better built spa overall..  JMO without offending anyone!  God forbid that should happen these days..
brillskill
« Reply #5 on: May 13, 2013, 10:34:55 pm »
Geo Nordic...who cares rangers up 5- zip!:)
« Reply #6 on: May 14, 2013, 02:05:23 pm »
Bruins are going to beat them in 6!
brillskill
« Reply #7 on: May 14, 2013, 03:01:16 pm »
no way..king henrik is a brick wall!
