Author Topic: Water Purification  (Read 12414 times)
jacksonbird03
Water Purification
« on: April 05, 2013, 01:29:02 am »
Hello members,,,
At home what is the best source to purify the water..
And is it good to use Iodine Tincture for the purification of water ???
Thank you in advance.. share your experience here.  :)
Water Purification
rosewoodsteel
Re: Water Purification
« Reply #1 on: December 08, 2013, 09:50:21 am »
In engineer friend of my swears by UV systems for home use.  He has installed a number of them commercially.  I am on well water and have a sand filter, acid reducing filter and a water softener.  When I have a little time (most likely after I retire), I will be installing a UV system, as well.   I don't know what it is you are trying to remove from your water, so you will have to do some research to see what type of system will work best for you.   Good luck!
« Reply #2 on: December 21, 2013, 10:41:10 am »
Hello members,,,
Purification is best done with chlorine. There are plenty of ways to supplement chlorine but nothing can purify better. If you want to be sure you have clean water chlorine has to be used. You can use other systems but then you have to assume.
Ryan VSO
« Reply #3 on: December 21, 2013, 01:20:29 pm »
Bromine is more stable than chlorine although
« Reply #4 on: December 22, 2013, 05:16:19 pm »
But bromine requires constant additions as in a floater or generator and isn't the halogen in Bromine the same as in Chlorine?
« Last Edit: December 24, 2013, 11:03:03 pm by Tman122 »
« Reply #5 on: December 24, 2013, 11:05:06 pm »
Purification is different from sanitation. Maybe that's the confusion.
« Last Edit: December 26, 2013, 09:32:44 am by Forum Admin »
