Author Topic: Viking II Spa - Blinking Light  (Read 3631 times)
xring600
« on: December 30, 2012, 05:12:20 pm »
My Viking II Spa light is blinking on and off repeatedly. I cannot change the temp either because the topside light control seems to be stuck and when the temp button is pushed it only changes the mode. Any ideas on what may cause this? Thanks in advance.
xring600
Re: Viking II Spa - Blinking Light
« Reply #1 on: December 31, 2012, 08:42:35 am »
I wanted to mention that the spa has a Balboa pack. Now the tub will not heat and the pump will not run, just the blinking light.
phillyboy
« Reply #2 on: January 05, 2013, 01:49:55 pm »
XRING,
Not sure if you got this resolved as of yet. It seems the blinking light indicates a problem with the system. At first thought, it may just be the pressure switch that has malfunctioned, but after seeing another post that the pump and heater are down, maybe the pack is in need of replacement.
phillyboy 8)
