Author Topic: Water Change just for the heck of it after 4mon?  (Read 5714 times)
TLWR
« on: December 01, 2012, 04:32:07 pm »
It has been 4 months, so it is time to change the Nature2 cartridge. The water seems otherwise fine. Clear, no foam, good readings etc.
Should I just put in a new Nature2 stick, or drain it?
(2 daily users)
Re: Water Change just for the heck of it after 4mon?
« Reply #1 on: December 01, 2012, 06:05:13 pm »
 Personally I would change it, why not?    Some for me would depend on where I lived.  If it's gonna get cold and snow soon then sure change it if it's a good time to do it.   If I lived in Cali I would not worry about it to much and change it when ever I wanted.
smackman
« Reply #2 on: December 01, 2012, 06:58:53 pm »
I guess its my water but I cannot get more than 2 months without changing my water due to foaming. The wife and I are the only users and we shower before and my water is balanced but foaming eventually happens. It is easy to change; I just wish I knew the secret. I have a Ozone generator and use very little bromine.
« Reply #3 on: December 02, 2012, 01:03:10 am »
Try raising the calcium hardness. That can stop the foam.
 8)
TLWR
« Reply #4 on: December 02, 2012, 09:09:00 am »
This is our routine. 2 adult users, and shower before use.
Tub is 220 gal, Caldera Kauai with ozone, 24/7 circ pump, and a nature2 stick.
1TBS MPS after nightly use
1TBS Dichlor weekly (Friday night after use, about a minute after adding MPS)
2TBS (heaping) Baking Soda (Friday night after use, about a minute after adding Dichlor)
after 1 month, rinse out filter
2nd month, 2TBS clarifier (in the morning), http://www.lesliespool.com/Home/Spas-and-Hot-Tubs/Spa-Chemicals/48169.html
That night after use, I pull the filter and clean it with 8oz filter cleaner overnight, Rince, and put filter back in. http://www.lesliespool.com/Home/Filters-and-Filter-Supplies/Filter-Supplies/14225.html
3rd month, rinse out filter
4th month, drain and repeat. Already soaked this morning (2x on the weekends) power is off, and will drain the tub after breakfast.
« Last Edit: December 02, 2012, 09:11:42 am by TLWR »
JohnnyK45
« Reply #5 on: December 02, 2012, 12:47:48 pm »
Our routine…
1)   Monthly, add one bottle of natural Spa Monthly by EcoOne
2)   After each use, chuck in one packet of EcoOne Shock
3)   Once a week, usually Wednesday, throw in two packets
4)   Once a month, swap out filters & let old ones soak for an hour with EcoCleanser; back on the shelf for next time
I will refill our 250 gal tub every 3-4 months; not that it needs it, but my tub is smaller, so it’s a quick process to drain and refill; all done within an hour.
J
TwinCitiesHotSpring
« Reply #6 on: December 02, 2012, 03:02:47 pm »
change it...fresh water feels great  ;D
« Reply #7 on: December 03, 2012, 07:20:40 am »
True,  and I would ask where do you live? I changed mine in late November, not because it needed it, but because it might be March before its warm enough to do so.
« Reply #8 on: December 04, 2012, 10:18:25 am »
That just so blows my mind... We served Thanksgiving dinner on our patio last month, and we might be serving Christmas dinner there as well.
 8)
« Reply #9 on: December 05, 2012, 07:35:25 am »
Do you wear suits? Do you wash those suits with laundry soap?  Residual soap in suits can cause foaming.  About the only time I see foaming is when a new guest wears their suit in our tub.
smackman
« Reply #10 on: December 05, 2012, 03:03:50 pm »
We never wear anything; BUFF.
« Reply #11 on: December 05, 2012, 05:58:38 pm »
Really? For Thanksgiving dinner? Wow.
 8)
« Reply #12 on: December 06, 2012, 10:37:06 am »
 8)
I think its been since 2003 since I was in Southern California, but I hope the next time I am there its winter here. I'm going to bring a snowball and throw it at your showroom window.   Makes a big splash, won't break the window  ;)
« Last Edit: December 06, 2012, 11:03:49 am by wmccall »
TwinCitiesHotSpring
« Reply #13 on: December 06, 2012, 12:19:12 pm »
 8)
sounds like a heck of a party  8)
smackman
« Reply #14 on: December 06, 2012, 05:28:17 pm »
 8)
Hell, We live in the country and our Hot Tub is in a screened in room with a 4" Insulated roof. It can get well down right graphic.  LOL ;D
Nothing like the country life until you need some maint. work done which has happened only once.
