Author Topic: Fountain Valley Spas  (Read 3879 times)
warlock73
« on: October 15, 2012, 09:59:54 pm »
Hey Gang !
I just got a Fountain Valley Spa (at least thats what the metal tag inside the motor compartment says) from an ad on craigslist.org. Free of charge. A guy who had it said it works but with a few small leaks. He did not want to mess with it for hassle purposes. ( he's around 60) Well I fixed the leaks and it works fine for the most part. This is my first spa and I have had NO luck searching on google for info on this. If anyone has info on where I may find an owners manual, that would be wonderful. I have several ?'s about it. It has a gray box in back of the motor compartment with a button that does nothing when I push it. A red light on this box also. It warms to 101 degrees and no more with thermostat all the way up. I would like it warmer. The metal tag inside says this: "Fountain Valley Spas, with a serial # of 1327178RS511185. Any info would help.
Thanks.
Re: Fountain Valley Spas
« Reply #1 on: October 16, 2012, 10:40:28 am »
Welcome to the forum!  I'm sure more knowledgeable people will be along shortly, but did you happen to notice any other company names on the control circuitry inside?
warlock73
« Reply #2 on: October 16, 2012, 11:10:54 am »
The control box inside says Len Gordon Company.
warlock73
« Reply #3 on: October 16, 2012, 01:41:57 pm »
I ran it in Low Speed Mode last night and today its to 104, but I do not want to run it all the time this way. I also hear the control box clicking about once a minute. Is this normal???
warlock73
« Reply #4 on: October 17, 2012, 09:40:49 pm »
Guess I came to the wrong website with no replies. Thanks anyway guys.
« Reply #5 on: October 17, 2012, 10:03:30 pm »
You probably aren't getting any replies because hat is a very obscure hot tub.  I believe they have been out of business for at leat 10 years.  You probably aren't going to have much luck with an owners manual because they haven't been around in a long time.  I doubt you are going to find many people who re familiar with this brand
Kmill
« Reply #6 on: October 18, 2012, 12:03:35 pm »
This "grey box" is probably the thermostat/high limit housing. The "click" should be the thermostat kicking on and off. Does it have a cable that spins when you adjust the temp on it?
