Author Topic: planetary's 2012 Jacuzzi J-470  (Read 22740 times)
planetary
« on: October 08, 2012, 10:32:06 pm »
Bought labor day, 2012.
Full gallery here.
Photos of delivery, setup, and first uses in late September, 2012.
« Last Edit: October 09, 2012, 12:20:12 am by planetary »
Bonibelle
  • '05 Marquis Epic
Re: planetary's 2012 Jacuzzi J-470
« Reply #1 on: October 11, 2012, 11:04:08 am »
Awesome!! Even the install was exciting!  Some of the best family conversations occurred with our two boys in the hot tub..Enjoy spending time with your family in your new tub!
JohnnyK45
« Reply #2 on: October 11, 2012, 11:57:20 am »
So very true!  I have two girls, and more so with my 4yr old, I hear about her school day, stuff she wants to do and we chat about the stars above - priceless time and fun memories...
Great photos; wonder if they asked anyone in the house to step out while they hoisted it over your roof?  :)
J
« Reply #3 on: October 11, 2012, 01:22:40 pm »
I do like the looks of Jacuzz's control panel and lighting.  I was so close to buying the J345.
jonnyboy2807
« Reply #4 on: October 13, 2012, 12:44:31 am »
Ditto.  I know aesthetic preferences are very personal but I thought this model was the most attractive tub of all the ones I saw, even in daylight in a showroom without the lights on.
That's a very nice set up, makes me want to move south....
« Last Edit: October 13, 2012, 12:46:02 am by jonnyboy2807 »
TdiDave
« Reply #5 on: November 04, 2012, 10:10:11 am »
I love the picutres, it looks great.
 Would you happen to have a shot of how you feed the electrical into the tub?  I have a j-480 coming in a few week and interested is some way to feed the power.
« Last Edit: November 04, 2012, 10:14:34 am by TdiDave »
planetary
« Reply #6 on: November 15, 2012, 07:52:20 pm »
Dave,
Just added a few pictures of the wiring to the main gallery.  I'll include them here.
First, my electrician drilled a hole into the bottom of the spa:
Then he secured the conduit to the concrete:
I previously had my landscapers provide an underground run from the hot tub to a nearby breakerbox location:
This is where the GFCI box is.  You'll see two condiuts, of course -- one coming from the tub, and the other going to the main house panel:
Inside the GFCI, it's pretty simple.  I recommend you go with the 60 amp wiring choice (not 50), so you can run all the pumps and the heater simultaneously.  It's a relatively small expense next to the tub, and it just guarantees that the temperature won't vary that much while you're using the tub:
Hope all this is roughly what you wanted to see!
TdiDave
« Reply #7 on: November 15, 2012, 09:08:15 pm »
Those are great, thanks for the update.
Did you have to put the hole in the spa?  I assumed it was already there. I was thinking about running hard conduit up along side and strait into the side with the sealtight so I can keep all of it very tight to the tub. Im not sure i can do it that way before the tub arrives (it would need to line up perfict)  But I see you just used sealtight the whole way up and bent right in, that maybe a easier option, but I think my electrician said no more than six feet of flexible.
planetary
« Reply #8 on: November 15, 2012, 11:36:53 pm »
Yes, my electrician had to drill a hole in the side of the spa.  Claimed it was pretty normal.  I spent a minute to check to see if there was an existing port or other method of ingress, but couldn't find one.  In any case, I don't notice anything now that it's set up, so I'm absolutely not sweating it.  :)
planetary
« Reply #9 on: May 11, 2013, 11:49:34 am »
It is with mixed emotions that I provide this potentially final update to my Jacuzzi J-470 story -- for I have sold my home and alas, the Jacuzzi cannot come along with us.
Our new home (assuming all continues to go well) will be a little under an hour away, and has a built-in pool and hot tub in a much larger back yard.  The new pool will be really great, but the hot tub... despite being "custom" and built-in is honestly a step down.  I weep for the lost therapeutic jets and tasteful design!
But the J-470 has been a great companion to our family over these scant 7 months, and much easier to maintain and enjoy than I thought it would be.  I shall miss it greatly!  However, the new owners of our home are thrilled with the Jacuzzi, and have asked all about it.  I hope they enjoy it for many years to come.
« Last Edit: May 11, 2013, 11:53:31 am by planetary »
« Reply #10 on: May 11, 2013, 01:30:36 pm »
  :'(  Hope the new place works out better for you!     ;D
