Author Topic: hot springs sovereign spa  (Read 3695 times)
na
« on: September 30, 2012, 07:09:00 am »
moto massager has no air to it have changed the air pipe can any one help
Re: hot springs sovereign spa
« Reply #1 on: September 30, 2012, 11:08:06 am »
Welcome to the forum.  We have several HS experts here that I'm sure will help. The Motomassage is great, I'd sure miss it.
na
« Reply #2 on: October 01, 2012, 10:47:54 am »
is ther any fixes to my problem there is no air supply to the moto massager there is adjustments to the 4 jets above
« Reply #3 on: October 02, 2012, 04:42:23 pm »
Have you checked the air control up on the edge of the spa? There is a control for the Moto Massage Jet, and one for the four small jets just above it. They are usually close together.
Also - is there water coming out of the Moto Massage? If the spa filter is dirty, it will slow the flow way down and can stop the movement of the Moto. If it is real bad it can also stop the jet from moving enough water to draw air.
And - of course - the Diverter Valve must be in the correct position for the Moto to get enough flow to do it's thing.
HTH
 8)
na
« Reply #4 on: October 03, 2012, 12:40:37 pm »
thanks for help have replaced the whole moto masseger jet as the rubber had small slit at joins thnks for help regards
