Author Topic: Simple Hot Spring Question  (Read 1921 times)
dagboi
« on: September 25, 2012, 05:22:03 pm »
Could someone please tell me what the voltage requirement is for the ozonator in a Limelight Pulse?
The tub is obviously 220v but is the ozonator 110v?
Thanks.
Re: Simple Hot Spring Question
« Reply #1 on: September 26, 2012, 07:52:27 am »
Yes, you are correct. The tub has many items on board which run on 110volts, such as the control system, circ pump (if equipped) lighting system, etc. The power feeding the spa is broken up in such a way that if you connect to the two "hot" wires you get 220v, but if you connect between one of the hots and the "Neutral" wire you will have 110v.
HTH
 8)
