Author Topic: Ozonator not working?  (Read 2636 times)
Mike32110
« on: August 11, 2012, 07:26:40 pm »
Hey guys, just wondering if I did something stupid. I have a 2002 beachcomber 580 that I bought used, and just got running and everything after fixing all the leaks. I noticed the bromine levels were really high at first so I turned off the ozonator for a day, and then turned it back on. This neon light was glowing when it was working originally, and now when I checked on it, it is not light up anymore.
Any ideas? Did I possibly do something to turn it off?
Re: Ozonator not working?
« Reply #1 on: August 11, 2012, 09:18:06 pm »
 Do you have a circ pump or does the spa heat via a main 2spd pump?   If you have a circ pump most spa's with or with out a circ pmp are designed to turn the ozone off when a main pump is running or has been running.   If you don't have a circ pump then the main pump needs to be running while calling for heat or in a filter mode.
Mike32110
« Reply #2 on: August 16, 2012, 04:36:31 pm »
Thanks for helping me out, you nailed it. :)
