Author Topic: can I use nature2 with a horizontal filter?  (Read 3544 times)
faeriegirl
« on: June 14, 2012, 11:20:55 am »
I wondered if it was possible to use a nature2 stick with my filter, as it sits horizontally in the spa?.. I hope so, cos I've read good things about it here on the forum. Thanks in advance, faerie
Re: can I use nature2 with a horizontal filter?
« Reply #1 on: June 16, 2012, 11:58:10 am »
You need to have flow past the N2 cartridge for it to work effectively. So - if you have a constant circ pump drawing water through that horizontal filter, or you set filter cycles which move water through that filter multiple times per day, it should work just fine.
HTH
 8)
faeriegirl
« Reply #2 on: June 16, 2012, 01:47:01 pm »
oh great! thank you so much :)
« Reply #3 on: June 16, 2012, 01:52:00 pm »
No charge.
 8)
faeriegirl
« Reply #4 on: June 16, 2012, 01:53:53 pm »
 ;D
