Author Topic: Problem related to circulation pump - low flo through heaters...  (Read 2041 times)
stevef
I own a 2006 SD Cameo 880 series spa.  I have been experiencing a problem where the heaters will not come on due to a low flow condition.  I have done all the obvious things - replace the filter, tried to clear the lines of any obstructions... it is very interesting that the heaters will work (low flo overcome) if I block the "second" inlet line to the bottom of my tub (evidently there are 2 outlets from the circ pump - and only one goes through the heaters).  By blocking the one inlet I can heat the tub.  Suggestions??  Is there a permanent screen - at the heater box?? - or something similar that could cause a partial blockage - and the low flo condition that I am battling??
clover
Re: Problem related to circulation pump - low flo through heaters...
« Reply #1 on: June 02, 2012, 06:00:18 pm »
Are you by chance on well water?
Have you tried running the circ pump without the filter?
