Author Topic: 2003 Marquis Reward Spa pumps not working  (Read 6316 times)
identman
« on: June 02, 2012, 06:48:24 am »
Both pumps on my Marquis Reward Spa are not working.  I have power to the control panel.  The fuses are ok.  I can hear a clicking noise when I push the power button to turn on the pumps.  No leaks around the pumps.  Any ideas what I should check next?  Thanks ....
Re: 2003 Marquis Reward Spa pumps not working
« Reply #1 on: June 02, 2012, 07:01:32 am »
Voltmeter on the output to the pumps - be sure you have correct voltage going out. It is possible that one side of the 220 volt breaker in your panel is tripped: that can leave some systems operating but not heat and pumps.
HTH
 8)
clover
« Reply #2 on: June 02, 2012, 05:41:36 pm »
Chas is right, you need to first verify that you have 240 volts leaving the control board and going to the motor.  If you have a voltmeter, and know how to use it, check the wires going to the motor.
Another shot in the dark, if the spa has been shut down for a period of time, and you are now starting it up again, the bearings “could” be seized up, with the power off, simply check the shaft to see if it will rotate and spin freely.
If you have 240 volts going to the motor, do you hear a humming noise coming from the motor when you attempt to start them?  Occasionally a start capacitor can go bad, but not 2 pumps at the same time.
clover
« Reply #3 on: June 02, 2012, 05:44:38 pm »
Ooops.   ::)
« Last Edit: June 02, 2012, 05:52:33 pm by clover »
