Original
Spa Bottoms
Pages: [
2
Topic: Spa Bottoms (Read 12361 times)
dazedandconfused
Full Member
Still Negotiating ....
Spa Bottoms
on:
May 21, 2004, 10:07:41 pm »
Are there any spa manufacturers that use a solid plastic cover on the bottom? What do Sundance and HS use?
I hate to see my future spa resting in water over the years. I can't imagine what it would do to all the wood inside.
Spa Bottoms
on:
Mendocino101
Ultimate Member
never ask for what you are not willing to give
Re: Spa Bottoms
Reply #1 on:
May 21, 2004, 10:12:42 pm »
Marquis spas do....They have what they call there durabase foundation...I believe that Sundance also has something simluar....
dazedandconfused
Full Member
Re: Spa Bottoms
Reply #2 on:
May 21, 2004, 10:15:44 pm »
Has anyone had trouble with moisture coming thru the bottom of their spas and decaying the wood structure? ANything I could do to prevent this from happening?
rick
Full Member
Re: Spa Bottoms
Reply #3 on:
May 21, 2004, 11:46:58 pm »
My Calspa experienced what you just described.
A neglected leak that caused the whole foundation to rot out. (when they came to haul it out, it would not move in one piece, it just started falling apart and they ended up sawing it into pieces to get it out of there.)When I first noticed the leak I called around and nobody wanted to touch it with a 10 foot pole, it being a full foam job. I then opened up the paneling and saw first hand what full foam looks like. It looks like somebody just started cramming assorted chunks of foam into this guy. I now pity anybody who is tasked with digging out such a leak.
Now my Calspa was pretty old too. It was probably close to 15 years old, it came with the house when I bought it.
So when the leak got so bad, (close to 1 foot loss of water per day), I started shopping and researching.
No, I claim to be no expert in spa design and while what I learned in my 3 weeks of searching is nowhere close to becoming an expert in the field, I did learn about the thermopane design and when I walked into the Coleman dealer I was doubly impressed with its all metal foundation. No wood whatsoever. This spa is also now much lighter than the "regular" spas,(unfilled of course) meaning easier to move in case I decide to change residences one day. I didn't spend over $8000 on a toy that I plan to leave with this house if I ever sell it. My toy is going with me to my new house, and I hope that it outlasts the 15 years that the CalSpa gave me.
To me, it just seems like common sense that the spa industry will move to this kind of design but you say the word thermopane on boards like this and the full foam guys just start bashing and making all kinds of claims of inherent problems with this design. I just don't know. Maybe they're all right. Maybe the day my warranty runs out this guy is going to start leaking like a sieve and running up my electric bill. Only time will tell, but I just have a better feeling all around about how my spa's made.
Ultimate Member
Re: Spa Bottoms
Reply #4 on:
May 22, 2004, 12:13:27 am »
Great question Dazed.
Personally, I find floors on the bottom of a hot tub somewhat redundant.
From a moisture perspective, if the materials used are pressure treated, this will never be an issue. Anyone built a deck recently?
The other reason would be to prevent rodents and such from entering the cavity. If this same 2X4 structure sealed the entire bottom edge, they would either need to come up through the cement foundation or eat through the pressure treated wood. Neither scenario is realistic.
The question should be, what materials are being used for the structure and will it be susceptible to rot? Does plastic break down over time? Does steel rust?
As for Rick, comparing a 15 year old design to concluding what type of insulation method is best currently, isn't really relative. This isn't a comparison on thermal "pain"
and it really has nothing to do with the question. I'm sure your tub will give you many years of pleasure but the decision of purchasing a fully insulated spa or not, equates to about 5% of the significant factors in this purchase.
rick
Full Member
Re: Spa Bottoms
Reply #5 on:
May 22, 2004, 12:19:03 am »
See what I mean?
And I disagree with the 5% figure. I'd add a 0 to the end of that 5. But that's just my opinion as a former "full of it" foam owner.
See, I can play nice.
Ultimate Member
Re: Spa Bottoms
Reply #6 on:
May 22, 2004, 12:36:30 am »
No problem Rick... You are allowed to disagree.
Electro
Re: Spa Bottoms
Reply #7 on:
May 22, 2004, 12:39:18 am »
dazedand confused,
I think this is an interesting topic and hope there are folks who can shed some light on what the big 6 hot tub makers actually have on the bottom. I don't think any sales literature addresses this.
What about it, dealers?
Electro
Mentor Level Member
Hot water is Cool.
Re: Spa Bottoms
Reply #8 on:
May 22, 2004, 02:08:38 am »
The bottom of a HotSpring spa is sealed with a layer of 60# density closed cell polyurethane foam.
It is almost as hard as the shell material - but thinner. It works well - my delivery guys can't even ram the tips of the forks on my forklift through the stuff, and believe me - they try.
Last Edit: May 22, 2004, 03:09:46 pm by Chas
doodoo
Full Member
Sundance Optima Owner - and lovin' it
Re: Spa Bottoms
Reply #9 on:
May 22, 2004, 08:28:11 am »
Dazed and condused. We looked at an Arctic Spa that had a full plastic bottom. Kinda like a full shell about 1/4'' thick and coming up about 4-6'' on the sides producing a mini casing that the tub sits in. I think?
In looking at the other method which is described by Steve is IMO more effective as it seals the base from moisture penetration.
dazedandconfused
Full Member
Re: Spa Bottoms
Reply #10 on:
May 22, 2004, 08:34:26 am »
Thanks.
Any Sundance dealers or owners out there? What is on a bottom of a Sundance?
Ultimate Member
2002 Optima
Re: Spa Bottoms
Reply #11 on:
May 22, 2004, 08:36:41 am »
I am not a dealer, but Sundance uses a hard plastic sheet attached to the bottom, different than the Jacuzzi Premium ABS pan.
Tubber
Re: Spa Bottoms
Reply #12 on:
May 24, 2004, 07:47:21 am »
Sundance has a full plastic hard sheeting underneath. With the front panels removed you can clearly see it.
"The bottom of a HotSpring spa is sealed with a layer of 60# density closed cell polyurethane foam. It is almost as hard as the shell material - but thinner. It works well - my delivery guys can't even ram the tips of the forks on my forklift through the stuff, and believe me - they try. "
This would make servicing the tub a little harder
dazedandconfused
Full Member
Re: Spa Bottoms
Reply #13 on:
May 24, 2004, 10:19:09 am »
So there is a definate plastic 'tray' under a Sundance?
I looked inside the HS's and Sundances and was surprised to see 2x4's for support! Wood! How long will that last?
I am surprised!
Ultimate Member
Re: Spa Bottoms
Reply #14 on:
May 24, 2004, 11:03:07 am »
Pressure treated pine will last a good long time.
So will naturally rot resistant woods like cedar and redwood.
I really have not observed what type of plastic sheeting is underneath our Optima, or how thick it is. But when I remove the service panel to access the drain, it seems good and dry inside.
Unless the plumbing springs an internal leak, I'd suspect it would stay dry.
Re: Spa Bottoms
Reply #14 on:
Pages: [
2
Original
Spa Bottoms
