Author Topic: Programming a Thermospa Concord Elite  (Read 3605 times)
bwg
« on: April 15, 2012, 10:17:26 am »
I wonder if anyone can help me with programming a Thermospa Concord Elite.  I have read the manuals and cannot figure out how to get pump 1 to shut off.  The directions are not clear at all and I am beside myself.  Or maybe someone knows directions to less complicated instructions.
Any help or guidance will be greatly appreciated.
Re: Programming a Thermospa Concord Elite
« Reply #1 on: April 15, 2012, 11:52:49 am »
  On most spas you just push the pump btn  ;)  press once for low speed, press again for high speed, once more it shuts off.    If you don't have a circulating pump, small pump that runs 24/7 then pump one will run on low speed when the unit is calling for heat.   If you have your spa set to 104, the pump will run more often to maintain that temp.  If you drop the temp down to say 80 then it should shut off.     If you just filled it, the pump should run till the desired temp is reached then shut off.    Is that what its doing??
