Author Topic: Understanding Jacuzzi 400 series filtration  (Read 4303 times)
smackman
« on: April 02, 2012, 01:50:41 pm »
I understand How the primary filter works. How does the secondary filter work under the polishing bag? I do not understand how flow goes through this secondary filter.
My primary circulation pump is set to run 6 hours a day for the primary filter.
 When I set the timer for the secondary filter, the same circulation pump comes on? What pushes flow thru the Secondary filter?
Re: Understanding Jacuzzi 400 series filtration
« Reply #1 on: April 02, 2012, 01:57:36 pm »
  It use to be pump 2 would draw through that filter.   Now it is pump one.
 You up and running yet?
smackman
« Reply #2 on: April 02, 2012, 02:03:52 pm »
Negative
smackman
« Reply #3 on: April 02, 2012, 02:11:27 pm »
Very little flow goes thru the secondary filter; It is almost useless unless I do not understand which is quite possible
« Reply #4 on: April 02, 2012, 06:07:33 pm »
  It's more for just redundant filtration.
