Author Topic: vita spa blown fuses  (Read 7590 times)
oldtown
« on: February 23, 2012, 07:48:05 am »
i have a vita spa 2007 that blew a fuse last week, after a long search i found the right one and replaced it.  So when i got in it last night the temp had not risen all the way or i did not set it high enough which i thought i did.  one of the 2 stage pumps would only come on high.  i ran a diagnostic test and i got a REL error.  i ran the test again and i got an F2 code error.  so this tells me that is probably the reason for the original blown fuse.
#1 is the relay bad?  how do i test it? #2 is the pump starting to fail?   please reply before my wife makes me call the technician.  thanks DA
Re: vita spa blown fuses
« Reply #1 on: February 23, 2012, 03:40:01 pm »
I'm with your wife.
« Reply #2 on: February 23, 2012, 05:18:29 pm »
Is your wife aware of this?
« Reply #3 on: February 28, 2012, 07:54:01 pm »
« Reply #4 on: February 29, 2012, 07:03:56 am »
Welcome to the forum.  I am a technical person my nature with a lot of troubleshooting experience, none of which is with hot tubs.  ;)  Over the past 9 years I have certainly heard of plenty of relay failures here.  Have you found the relay?  It is removable? Can you see any signs of burning around the relay or its socket?
« Reply #5 on: March 01, 2012, 10:36:07 am »
First, let me make it clear that this sounds like one of those times when you would be better off getting a pro to fix this - or at least troubleshoot it.
But having said that, I would proceed like this:
Disconnect the pump in question from the control system.
Test the output of the relay(s) -
   Be sure it IS sending power to the pump,
   Be sure it only outputs to ONE speed at a time.
   Be sure it is not stuck 'on' for either speed.
Then test the pump -
   Put power to the unit and see that both speeds work, one at a time.
   Don't run the pump dry.
And go from there.
HTH
 8)
