Author Topic: Opinions on alternatives to chlorine/bromine  (Read 45902 times)
chem geek
Re: Opinions on alternatives to chlorine/bromine
« Reply #30 on: October 20, 2011, 01:29:36 am »
... you are still required to use Chlorine with the system per their directions. Yes, you do use less, but still required to use chlorine.
You don't use less chlorine compared to properly maintaining the spa with chlorine alone.  It's only if you don't maintain the spa properly and allow biofilms to form when doing chlorine-only that you could create extra chlorine demand.  That is, Aqua Finesse can insure against improper chlorine maintenance, but it doesn't reduce the amount of chlorine needed to oxidize bather waste because Aqua Finesse does not contain oxidizers or enzymes.  So people who use too little chlorine because of any claims that less chlorine is needed can have that chlorine level get too low.  Those who use the spa more frequently and have an ozonator basically have ozone doing most of the oxidation and is why the people who have had the most success with Aqua Finesse are those that have ozonators.  The proper way to view Aqua Finesse is as an (expensive) increment to a regular chlorine regimen.  If it provides perceived value, then that's fine, but it's not a chlorine substitute nor a chlorine reducer compared to a properly maintained chlorine-only spa.
This long thread discussion about Aqua Finesse includes posts from a U.S. representative of the company and some users who like it and some who don't.  There are quite a few other threads and posts on that and other forums.  The claim from the manufacturer of 80% lower chlorine use only occurs when compared to out-of-control chlorine-only spas with biofilm problems or when you don't count the Aqua Finesse Trichlor pucks/tabs as part of the chlorine usage (see the MSDS from this page for such spa tabs to see that they are Trichlor).  You can certainly add less chlorine (remember to include the Trichlor tabs in your count of how much chlorine you are adding), but it won't maintain a level if you don't add enough (and don't have an ozonator) with the result of your soaking in your own sweat and urine.  I look at Aqua Finesse in a similar vein as Nature2 in that they are extra-cost insurance to prevent runaway bacterial growth if the sanitizer level gets too low.  Some of the other main benefits can also be accomplished through a combination of Trichlor pucks/tabs in a special slow feeder, baking soda to raise the TA destroyed by the acidity of Trichlor, and a pH buffer such as a phosphate buffer (reduces calcium hardness as well) which minimize the amount of maintenance (though with some side effects like rising CYA).  Or instead of a phosphate buffer one can use a boric acid product such as ProTeam® Gentle Spa which also moisturizes and feels silkier, but should be used with a less acidic chlorine source (i.e. Dichlor or bleach).
« Last Edit: October 20, 2011, 03:26:33 am by chem geek »
d00nut
« Reply #31 on: October 20, 2011, 01:44:48 pm »
LOL Doonut, and you hate Aqua Finesse because that is what your competitors sell?
You do use less sanitizer because your not fighting biofilm related bacteria and it helps inhibit the growth of bacteria.  The product was made for large water coolers (much larger industry then pool and spa)
Just like as time goes on you will require more and more chlorine use from when you first owned the spa...that is generally do to biofilm which introduces and produces more bacteria in the spa.  Lets not pretend people take great care of their water...Aqua Finesse lets them be a little more lazy then normal systems.  Maybe the spas I see in the field are different then the ones you see...but when customers are RUINING their hot tubs do to neglect, Aqua Finesse or Silk Balance might be the answer.  I like Aqua Finesse because it costs less, works better and doesnt stain your filters (Yeah I went there! :) )
You just contradicted your previous post here.  You say it works better and does not stain your filters... then the ingredients cannot be the same.
I've personally tried both, and I prefer Silk Balance and that's why I chose to floor that over Aqua Finesse.  Cost is relative to what people think the product is worth to them.
P.S.  I don't typically tout the ease that comes with Silk Balance, I normal let people know that it will allow them to avoid the drying of their skin, which is what most people want.  I still educate them on proper water maintenance.
marky mark
« Reply #32 on: October 21, 2011, 07:58:38 pm »
ChemGeek / Spatech_two:
I just bought a tub. 1st one ever. Don't know much about the sanitizing system except what the dealer told me. I use Bromine as that is what they recommended. It is a Sundance Altamar with a Ozonator. I will have my grand kids in it and want to know the best system to use. They are 5 and 6 years old, I keep the temp at 98 when they are in it, but want to be sure I am not exposing them to anything harmful. What do you recommend? I have only had it a few days. Thanks.
