Author Topic: Advice on cover lift  (Read 2609 times)
jmosery
« on: September 23, 2011, 09:23:01 am »
We need to buy a cover lift
I see some that you screw brackets into the tub side or their are undermount ones
which do you find better?
the undermount ones, do you have to have your tub empty and lifted to slide it under? I haven't looked the bottom of my tub
I see a lot of those Cover Mate covers around. good? recommended?
We have a Sundance Chelsea hot tub
the cover is easy to lift off ourselves but I hate how it just sits on the grass(dont want that in the winter) and dont want the cover to get ruined
also, what about something like this:
http://www.spadepot.com/shop/Cover-Catch-P9330C49.aspx
Re: Advice on cover lift
« Reply #1 on: September 23, 2011, 09:59:39 am »
The undermount ones do require you to have the tub empty.  My tub is in our back yard and nobody else sees it, so i have no problem drilling a few holes in the cabinet.
sorebikr
« Reply #2 on: September 23, 2011, 10:17:05 am »
If you get the side mount ones, make sure they mount to two sides of the tub that do not include your access panel.  I'm running into that issue with my tub (for a number of reasons).  I'm going to cut out part of the access panel so I can remove it, without having to unscrew the cover lifter.  Pain in the neck, but as someone else said, its not like anyone is going to see the cabinet in the future.  And if I do this right, it shouldn't be tooo noticeable.  I hope.
jmosery
« Reply #3 on: September 23, 2011, 11:21:15 am »
when we empty the tub for water changes, can we then lift the tub(my husband and I or is it too heavy?
i dont mind screwing it into the tub but just easier if we can just place is underneith
« Reply #4 on: September 23, 2011, 11:40:09 am »
You only have to lift the tub about 1/4" to slide the brackets under. A small pry bar works wonders.
