Author Topic: Filtration in hot tubs  (Read 139511 times)
Re: Filtration in hot tubs
« Reply #135 on: April 28, 2006, 10:50:16 am »
Whether pump 1 is on high speed for jets or on low speed for heating, filtration cycle, or clean up cycle, ALL of the water goes through the filters.
Except, of course, all of the water going through jet pump 2.
East_TX_Spa
    • I Love My Spa
« Reply #136 on: April 28, 2006, 11:03:33 am »
I am curious as to how Pump #1 can be tied into the filters and Pump #2 is evidently not.  I am also curious as to why some of the models have 4 by-pass valves in them if they are not really by-pass valves like everyone else uses. :)
Terminator
« Last Edit: April 28, 2006, 12:38:23 pm by East_TX_Spa »
Bonibelle
  • '05 Marquis Epic
« Reply #137 on: April 28, 2006, 11:46:39 am »
Somehow it would be much more impressive coming from the spa fairy's ...mouth ::)
RPG
« Reply #138 on: April 28, 2006, 12:30:12 pm »
My Texas friend simply seeks accountability in the spa industry claims, nothing more.  I'm sure we all want honesty and forthrightness to be upheld on this wonderful forum that is a great source of information.
Always be prepared to validate your position and the truth will set you apart from the riff raff.
Bonibelle
  • '05 Marquis Epic
« Reply #139 on: April 28, 2006, 12:59:18 pm »
There is just something about that fairy...I don't know if it's his tights or that wand...but he is just so credible..I'm sure if we could just hear his voice...it would bring fond memories of Mrs. Doubtfire....
« Reply #140 on: April 28, 2006, 01:48:33 pm »
IF Marquis doesn't have a bypass valve on the filters, and IF the bottom suction does indeed send the water through the filter, then it will have joined the ranks of truly world-class spas which filter all the water moved by it's jets.
Of course, only half of a Marquis would be world-class* since only one of the jet pumps filters while the other does not filter AT ALL.
[size=10]*in some parts of the world this would be known as 'half classed." ;) [/size]
« Reply #141 on: April 28, 2006, 05:23:14 pm »
I didn't know they allowed Fairies in Texas.
Ronald5599
  • HS Envoy installed May 5th - Very frustrated
« Reply #142 on: April 28, 2006, 08:45:57 pm »
Well, again, thanks a lot for all the comments on this thread. Wow, I am so confused about all of this I guess there all pretty good. I decided to stick with the HS Envoy. We are having it delivered next Friday AM.
Wisoki
  • YEEEEEEhaw
« Reply #143 on: April 29, 2006, 10:32:54 am »
Too bad Bill's not here to read this, or that I'm late in replying but........."There aint nuthin it Texas but steers and queers, and I dont see no horns on you boy!"
« Last Edit: April 29, 2006, 10:33:38 am by Wisoki »
« Reply #144 on: May 01, 2006, 11:16:37 am »
Isn't Austin in Texas?
East_TX_Spa
    • I Love My Spa
« Reply #145 on: May 02, 2006, 10:27:55 am »
Yep, right in the tain't.
Terminator
