Author Topic: HELP!!!!!!  (Read 3089 times)
elbretz
HELP!!!!!!
« on: September 10, 2011, 02:07:54 pm »
Just got old not sure of year hot springs prodigy tub around the 1995's maybe but the heater and circ. pump dont work not sure what to do if anything any help would be awsome thanks
HELP!!!!!!
elbretz
Re: HELP!!!!!!
« Reply #1 on: September 10, 2011, 05:40:40 pm »
Someone has to know something come on guys I need some help.
d00nut
Re: HELP!!!!!!
« Reply #2 on: September 10, 2011, 08:10:21 pm »
If the circulation pump doesn't work, then the heater won't work.  You might want to try to flush out the circulation pump line with water to make sure you knock loose any air bubbles.  If that doesn't work, you may need to replace the circulation pump.
Looks like you just acquired the hot tub, was it working before you got it?
sorebikr
Re: HELP!!!!!!
« Reply #3 on: September 12, 2011, 09:08:39 am »
Not trying to be rude, just direct:
If you expect someone you've never met to sit down, think about your problem and then take more time to write out a thoughtful intelligent solution, you should expect to have to put in some more effort yourself in your request.
-What have you tried so far?
-How long have you had the tub
-Did you contact the previous owners
-Can you post picture of the motors, including any identifying information (serial numbers/model/year etc)
Re: HELP!!!!!!
