Author Topic: Question on electric for our Sundance Chelsea spa  (Read 3126 times)
jmosery
« on: September 01, 2011, 08:43:16 pm »
my father in law is an electrician but has never done hot tubs
we bought the Chelsea
he said that the paper explains that with a 50 amp electric, we can't run the heater and the pump at the same time
he saids 60 amps is required
anyone know?
the electrician we hired wants to do 50 amps but isn't the point of the 24 hour circulation pump for it to be able to run when needed? do we have to turn off the heater to run the jets in the tub with 50 amps?
any info would be helpful
thanks
jaime
Charger Fan
  • Go Bolts!
Re: Question on electric for our Sundance Chelsea spa
« Reply #1 on: September 02, 2011, 12:07:52 am »
If you want to run the 24 circ. pump, BOTH high-speed jet pumps, AND the heater at the same time, you need the 60 amp breaker.  A 50 AMP breaker will work, but the heater will not operate if you have both high-speed pumps on at the same time.  The circ. pump will continue to run even though the heater doesn't.
