Author Topic: Grandee install - room for water to run under?  (Read 4625 times)
eebuckeye
« on: August 31, 2011, 10:46:07 am »
I want to install the hot tub on a cement pad that is essentially flat but does have a drain flush with the concrete in the middle of the pad.  Can I put the Grandee on top of the cement allowing a little water to run below to the drain?
« Last Edit: August 31, 2011, 10:49:00 am by eebuckeye »
