Author Topic: Spa PAD- what to put under it  (Read 4233 times)
jmosery
« on: August 30, 2011, 09:16:16 am »
we bought a spa and spa pad
do people just pull the grass up, level and put sand under it? we are getting pavers put around the spa pad(4 feet all around) but wasn't sure what people did UNDER the spa pad itself
my husband was thinking sand or those little gravel rocks
jaime
soak-king
    • Backyard Oasis
Re: Spa PAD- what to put under it
« Reply #1 on: August 30, 2011, 10:59:08 am »
jaime
All you need is level ground, using sharp sand to fine tune the level and create a base is a good idea.
Spa_Tech
  • Independent Spa technician
« Reply #2 on: August 30, 2011, 09:01:13 pm »
jaime
Agreed. Last spa move I did had a spa pad simply laid over existing lawn.
