Author Topic: Caldera Ozonator injector???  (Read 6072 times)
rphman
  • Caldera Moorea 07
« on: August 08, 2011, 09:06:07 pm »
Looking for some help. I just bought a new Monarch CD ozonator for my Caldera Moorea that didn't come with one. The kit I bought has a red injector (highland series) and SpaDepot shows my tub has a blue injector (paradise series), the tubing sizes, and main unit are identical. The parts look the same except color but the injector hose is in a different place  see http://www.spapartsdepot.com/category/caldera_spas.ozonators/ Does anyone know if there is a difference? Thx
Re: Caldera Ozonator injector???
« Reply #1 on: August 09, 2011, 10:57:10 am »
The difference should have to do with whether your spa uses a circ pump for filtering or a 2-speed pump for filtering. There is a big difference in flow between the two methods and the color injector is to match the flow of that line. Stick with what the manufacturer suggests.
« Last Edit: August 09, 2011, 11:18:51 am by Spatech_tuo »
rphman
  • Caldera Moorea 07
« Reply #2 on: August 09, 2011, 11:06:16 am »
Thanks Spatech!
d00nut
« Reply #3 on: August 10, 2011, 01:31:30 am »
Red injectors are for spas that use a low speed jet pump to filter the spa.  If you have a circulation pump, they are typically white/clear/black, and I guess now blue.
rphman
  • Caldera Moorea 07
« Reply #4 on: August 10, 2011, 06:06:24 pm »
Yeah I was worried about the injector but didn't realize there are voltage differences in the units also! :'( I bought the correct injector but know just realized this unit is 120 volts and my tub is 220 volts, so now I have a complete setup for 120 system and just an injector for a 220. If anyone is interested in a  brand new in the box Monarch CD set for a 120 volt tub let me know as I can not return it.
d00nut
« Reply #5 on: August 10, 2011, 06:35:09 pm »
I may be wrong, but I thought all Watkins spas use a 120V Ozone.  Are you positive that yours must be 220?
rphman
  • Caldera Moorea 07
« Reply #6 on: August 10, 2011, 07:11:42 pm »
No I don't thats way I kinda asked here. I did start a new thread. Spaparts depo said 120, I assumed since mine was set up for 220 that it had to be 220?? But maybe that part runs on 120 off the board?? I got confused as after I saw them listed for either voltage when I ordered the injector and then read the sellers desciption that it would work in any 120 volt tub.
« Last Edit: August 11, 2011, 03:15:24 pm by rphman »
« Reply #7 on: August 11, 2011, 07:28:49 pm »
All Watkins tubs use 120 volt Ozone systems.
d00nut
« Reply #8 on: August 11, 2011, 08:07:36 pm »
I got something right, awesome.
rphman
  • Caldera Moorea 07
« Reply #9 on: August 13, 2011, 12:07:50 am »
Thanks Chas! That's what I wanted to hear. I may have not posted alot, but have read many of your posts and appreciate your help to the forum!!
rphman
  • Caldera Moorea 07
« Reply #10 on: August 13, 2011, 06:28:19 pm »
I guess if I looked in the control box it gave the different voltages for the components. Very easy to install and is working. Thanks to all that replied with answers!
