Author Topic: Choosing Hot tub  (Read 7965 times)
Stephenh
Choosing Hot tub
« on: August 02, 2011, 01:31:29 pm »
We're looking at two models, the D1 Californian and the Sundance Cameo(or Optima).  I'm choosing these two due to the presence of local dealers, as I'm sure other brands are good also-
We've wet tested the D1 and will test the Sundance soon.  One question is the actual capacity of the tub-the D1 lists 350 gallons in the spec, but the Sundance is listed at 450 gallons, which is a pretty big difference.  However, the manual for the Sundance lists 370 gallons as the average capacity(for chemical purposes).  The Sundance seems a bit deeper, but that doesn't explain the difference.
Some observations:
The Sundance is a little "nicer"-possibly because of the acrylic shell.  I know this is a dead horse, but it strikes me that the acrylic is more likely to craze than the "ultralife".  What is the difference in backing(of the OAS or acrylic) between the two.  The "lifetime" guarantee on the D1 is attractive(even though I know you have to ship the whole thing back-still its better than nothing).
The water effects on the D1 are a little cheesy-the waterfall is better on the Sundance, even though both are gimmicks.
The filter assembly on the Sundance is a bit of an eyesore-what is the advantage?
Two speed pumps on the D1-is that a practical advantage?
The SS handles are nice on the Sundance, gives it a classy feel.
The D1 dealer seems like they will be more helpful-are will to do a site inspection without any order.
The Sundance has open cell foam insulation(accorrding to the dealer), mostly. I thought this was a bad thing(can get soaked with a leak-I don't think the R-value is much different)
D1 is priced at 9600(with lights, etc), Sundance at 10400, both with lifter cover, steps, delivery, chemicals, etc.
I'm not interested in ripping either brand, they both seem pretty good, just finding out all of the differences, so when we wet test both again, we'll know what to look for.
I'm suspecting the operating costs will be similar depending on how much water the tubs actually hold-I live in CA so weather is generally mild.
Choosing Hot tub
Re: Choosing Hot tub
« Reply #1 on: August 02, 2011, 05:02:17 pm »
I never totally trust the stated gallons on spa websites. I've seen the same spa go unchanged from 1 year to the next but all of a sudden the next year it somehow is spec'd to hold an additional 50 or 75 gallons on the website/brochure. I'd ignore this part.
Some observations:
Sue, the Sundance may be apt to craze more (which is totally aesthetic so I wouldn't give it much thought). While I think they're pretty even overall I'd probably take a 10 year full shell warranty over a "lifetime" warranty that states after year 7 I may have to send it back. In reality I'd ignore shells other than maybe if you like a certain color that the other doesn't carry.
The water effects on the D1 are a little cheesy-the waterfall is better on the Sundance, even though both are gimmicks. Agree
The filter assembly on the Sundance is a bit of an eyesore-what is the advantage? None, I'd ask about getting a normal filter rather than the very costly disposable one designed to sell you a filter far too often.
Two speed pumps on the D1-is that a practical advantage? Not to me.
The SS handles are nice on the Sundance, gives it a classy feel. Eye of the beholder.
The D1 dealer seems like they will be more helpful-are will to do a site inspection without any order. Your feel for how much the dealer will be there after the sale is important.
The Sundance has open cell foam insulation(accorrding to the dealer), mostly. I thought this was a bad thing(can get soaked with a leak-I don't think the R-value is much different). Both are full foamed in a very similar way which is good IMO.
D1 is priced at 9600(with lights, etc), Sundance at 10400, both with lifter cover, steps, delivery, chemicals, etc. How much does that price difference mean to you over the 10, 12, 15 years you hopefully will own it?
I'm not interested in ripping either brand, they both seem pretty good, just finding out all of the differences, so when we wet test both again, we'll know what to look for. Get to wet testing, that will tell you a lot.
I'm suspecting the operating costs will be similar depending on how much water the tubs actually hold-I live in CA so weather is generally mild. I suspect the same.
« Last Edit: August 02, 2011, 05:03:56 pm by Spatech_tuo »
d00nut
« Reply #2 on: August 02, 2011, 06:36:42 pm »
What did you think of the D1 when you wet-tested it?  Test the Sundance, that's really the next step.  Both are great brands, but you'll never know the difference until you actually sit in it.  Are the prices off the floor or whatever you want to order?
Stephenh
« Reply #3 on: August 02, 2011, 07:42:55 pm »
Prices were for an ordered tub, before taxes.
d00nut
« Reply #4 on: August 02, 2011, 11:40:08 pm »
Color and how jets feel should be the last determining factors then.  The lifetime warranty on the D1 is based on the structure, which should really never fail.  If anything, I'd say the Sundance shell is more substantial than the ultra life shell.
Stephenh
« Reply #5 on: August 03, 2011, 12:32:54 am »
Actually, the d1 shell is warranty also covers blistering and cracking, for what its worth.  I agree, though, that the sundance shell looks pretty solid.
ejf The Spa Guy
  • THE SPA GUY
« Reply #6 on: August 03, 2011, 12:38:18 pm »
both brands are on the top tier listing. you cannot go wrong either way. On the shells both companies use the same acrylic shells form the same company,,,so that would be an even par, But yes D1 has the Ultralife shell. the advantages of the shell, the tub can be left empty in the sun and not void the warranty like the acrylic shells they both use. Lucite and Arystech are 2 companies that make acrylic sheets for the tubs....the other thing is the maintenance of the shell, you can use a green kitchen scubby if need be to clean the spa and it won't scratch ( acrylic will) also if there is a gouge , on the Ultralife you can fix it and not tell were the gouge was by a standard tech in the field, the acrylic repair will always be seen on the repair not as easy fix for a standard spa tech . I have made repairs on both.... also yes the warranty,,, the Ultralife gives yo9u a lifetime warranty on the shell. For the life that you own the spa it will be repaired, but if the crack is deamed to big then yes it would have to sent to the factory for repair, the customer would have to pay the freight but the repair is covered, now if you get either the D1 or Sundance in the acrylic shell and have a problem in the field , they have a shorter warranty period for the shell, and if the job is to big and has to be sent to the factory the consumer is on the hook for both freight and repair....
On the gallons they are about the same and the cost of running will be close as well.
On the shells : the backing on the shells the D1 use an ABS backed productlow voc's and less chance of delaminating, the Sundance has the rigid bonding with fiberglass, yes it is thicker but the warranties are about the same....
On the 2 2 speed pumps, i think that is an advantage,,, if you get in the spa by your self and wanting to sit in the back corner were the jets are run by pump 2, you can turn only pump 2 on without pump 1 for starters and also having a low speed or high speed more adjustment available and air adjustments inside the tub at the jets, not on the air valves that adjust more than one seat.
On the filters both filter the water, but why the horizontal filter they are the only ones who do this.... also they have the prefilters that replaced more often,, i would check into the standard filter, but again different ways to build a mousetrap, i think the vertical filtration filters do a better job , water getting sucked down thorugh the filter housing, on the horizontal comes over the skimmer and gets sucked to the sides,,, i think the vertical filter gets more coverage ......
Both spas are full foamed they both will hold the temp very well and very efficient,,,
The waterfall on the D1 is what it is,,,, it is different and can change the cap for different style water flow.... the waterfall in the Sundnance is nice, the only thing i don't like is the discoloration of the waterfall after 3-4 years the plastic turns to a oranger color.....
But the biggest thing i would check is the dealers you are working with, i like the idea of the presite, We also do this... in this time were customer service is key, it tells you who wants your business.. also check out the service after the sale and what they offer, do they hav a google places page with reviews, you might check them out.....
good luck you have to very good brands you are looking at.
« Reply #7 on: August 03, 2011, 02:32:12 pm »
I would ask the second dealer if they'll do a pre-site for a couple reasons. 1) I'd bet they would and that would even the score and 2) if they said "no" then you know they may not be willing to give the customer service on other things in the future, that would be a good indicator to me.
ejf The Spa Guy
  • THE SPA GUY
« Reply #8 on: August 03, 2011, 08:20:10 pm »
good point spatech, that will help you find the dealer to buy from,,,
one thing that is also different is the ozone system, D1 has a 3 chamber u.v system, and it doesn't off gas in the main body of water.,,,
d00nut
« Reply #9 on: August 04, 2011, 12:08:07 am »
So you can never tell when your Ozone is actually working or not!   ;)
ejf The Spa Guy
  • THE SPA GUY
« Reply #10 on: August 04, 2011, 11:56:46 am »
yes and no. most ozone systems on a 24 /7 circ will run when the pump is on , thus you will see the ozone bubbles... a way to know is by removing the pump compartment door, ozones will have a light usually grren, blue or an indicator,, some ozones will last 3-4 years, some longer, some manufacturers recommend you replace every 18 months,,,,the other way to know if your ozone has stopped working is the water maintenance,,,
Stephenh
« Reply #11 on: August 04, 2011, 12:44:59 pm »
OK, also found a local Hot Springs dealer and wet tested them all:
1. D1 Unfortunately, fell to 3rd place.  Least comfortable, feels cheap(Californian).  Best dealer though, I feel bad about not buying from them.
2. Sundance.  Good quality, nice hefty shell, handles are a great idea, big tubs.  However, jets were not that strong(according to the wife who is the final say), and more so were in the wrong places(mostly at upper back, almost nothing at lumbar L4,L5 where most people have back problems).  Least helpful dealer-I think will not be overly helpful in practice.
3. Hot Springs.  Good quality, better and stronger jets, overpriced.  Not too enamored with the motorized jets though-seems like something that won't last.  Dealer seemed OK, willing to do a presite without an order.  What is the deal with the Watkins special subpanel?  Got a quote for an Aria(with steps, lifter cover, delivery, subpanel, the usual chemicals, etc) for $10800, which although "discounted" from the ridiculous MSRP is pretty steep for a relatively small tub.  Also liked the Limelight(lower end Hot Springs) flair for $7900.  Wife's favorite brand. Her big issue was with jet strength and placement. We'd like to get the HS(Vista, Envoy , or Aria), but the price has to come down-how much negotiating is realistic?
For all the tests, we asked the dealer to give us the strongest setup for the jets in a any given position(if we got the wrong impression, it was the dealers fault for not knowing his product).
ejf The Spa Guy
  • THE SPA GUY
« Reply #12 on: August 04, 2011, 12:55:30 pm »
stephenh,
nice to see your process, When you looked at the D1 did you by chance see the Chairman II that has alounger also , little different on the design, I think has a better fit the Californian, not so much slope, Ultralife is one of my best sellers, I also sell alot of the acrylic shells in the Graphite, and the Moonstone... You should check out the Chairman you will like it better and has more features to it as well....
« Reply #13 on: August 04, 2011, 01:16:28 pm »
...but the price has to come down-how much negotiating is realistic?
I like the fact you're taking your time to determine what spas fit/feel best (like only a wet test can do) and what you think of the dealers but pricing can be a guessing game.
Did the dealer give you a quote that he knows he can work off of or was it firm? I think I’d tell them straight up "We’re interested but when comparing with other places we’ve shopped we really need your best offer to before we go any further". I’d then resist any follow-up question designed to get me to counter such as “what is your budget" or "how much you're willing to pay" and tell him straight up in a polite yet firm way "You certainly know what your bottom line is, please skip any steps in between and tell me the absolute best offer you're willing to go to and we'll either seriously consider it or move on". That should motivate them to take you as a serious customer who expects their best deal.
d00nut
« Reply #14 on: August 04, 2011, 04:10:41 pm »
The Moto-message has been around longer than I've been on this earth.  Water Chemistry is the biggest threat to damaging those jets, as with any jet.  The sub-panel just has to do with the wiring of the tub.  It comes with the spa, so that shouldn't be factored in (plus it's included in the component warranty for 5 years.)  I believe on that spa, the heater is ran by the 20A breaker and everything else is on the 30A.
The price seems in line with what I sell that hot tub for.  Overpriced?  To some maybe, but if it is exactly what you want, what is $1000 over 10-15+ years you have the hot tub for?  Fact is, it is an expensive tub for the dealers, so it's an expensive tub for you too.  A great tub I might add, one of our best sellers.
P.S.  All MSRPs are pretty high.
