Author Topic: HotSpring - Vista 2011 - circulation pump  (Read 2629 times)
robmet1015
« on: July 24, 2011, 11:20:55 pm »
I am researching for a new tub and was trying to see how much water per hour the SilentFlo 5000® circulation pump filters each hour?  Does anyone know this answer or a resource to serach on?
I am comparing the various other features with tubs and curious how much water is filtered in this tub...
Thanks.
Rob
« Last Edit: July 25, 2011, 08:30:25 am by robmet1015 »
TwinCitiesHotSpring
Re: HotSpring - Vista 2011 - circulation pump
« Reply #1 on: July 25, 2011, 01:04:27 am »
the entire body of water in the Vista (500gal.) will "turn over" 12 times per 24hours approx.
« Last Edit: July 25, 2011, 01:08:16 am by TwinCitiesHotSpring »
robmet1015
« Reply #2 on: July 25, 2011, 08:32:40 am »
Thank you.  Where did you see this info at?
« Reply #3 on: July 25, 2011, 10:56:19 am »
It was either published and he copied it to you or he simply knows the gallons/minute of that pump and did the math for you knowing the size of the body of water.
TwinCitiesHotSpring
« Reply #4 on: July 25, 2011, 04:08:01 pm »
I do not believe I have ever seen this info. published in any "customer literature" but in some service documents there is a procedure on how to test the flow on a circ pump which are service techs do on "end of warranty inspection" visits using a standpipe and a bucket....that plus some math (ok a calculator lol) and I came up with the numbers above
