Author Topic: ozone bulb  (Read 2472 times)
kuff
ozone bulb
« on: June 30, 2011, 01:43:56 am »
How hard is it to replace the ozone bulb on a D1 Chairman II?
ozone bulb
clover
Re: ozone bulb
« Reply #1 on: July 02, 2011, 01:13:01 pm »
Simple, take one out and put the other in it's place and plug it in, job done.  TURN THE POWER OFF FIRST.
ejf The Spa Guy
  • THE SPA GUY
Re: ozone bulb
« Reply #2 on: July 02, 2011, 03:57:08 pm »
Kuff, Shut off the power to the tub, Open up the control bow, you need a phillips screwdriver, loosed the screws on the cover, lift up and pull off, You will see the ozone generator in the top of the box, follow the wire off the lower left side of the ozone to the connector , unhook, now at the generator there are 2 metal tabs hanging down with a screw in each remove the screws, pull out the ozone, put the new one in, align the screw holes( it may be a partial hole on the generator, go ahead a screw into the holes, plug in, put cover back on, turn the power on , you should be set...
Re: ozone bulb
« Reply #3 on: July 04, 2011, 09:41:33 am »
Be sure you check for corrosion first, before you go out and buy the bulb. The bulb can be close to the price of a new unit - in fact many bulbs cost more than a complete CD unit. So shut off the power, open your ozone unit and see if it has corrosion issues. You don't want to spend the $$ on a new bulb only to find out the rest of the unit - that would be the box itself and the power supply - are not going to give you another couple years of service.
kuff
Re: ozone bulb
« Reply #4 on: July 06, 2011, 03:17:47 am »
Thank you guys.
Re: ozone bulb
