Author Topic: Cover or Leak  (Read 2231 times)
jbduffy1
Cover or Leak
« on: June 24, 2011, 07:44:18 am »
2007 Sundance Optima 880. Started noticing water loss in the winter. But we use it everyday. But now I see the level dropping after 3 days and needs water more often. Could the cover be shot and wicking water away due to evaporation? I have Spa close to the house and will have to disconnect and roll away from foundation to tak eoff panels. Any have similar conditions?
Cover or Leak
Re: Cover or Leak
« Reply #1 on: June 24, 2011, 09:47:30 am »
It's not the cover.
Re: Cover or Leak
« Reply #2 on: June 24, 2011, 09:56:57 am »
Is there any obvious signs of water at the base?
ejf The Spa Guy
  • THE SPA GUY
Re: Cover or Leak
« Reply #3 on: June 24, 2011, 01:59:34 pm »
i would check for a trail of water at the base, you might open up the pump compartment. run the pumps, take a look and see if there is a loose union a bad pump seal,,,if nothing there you might mark the interior on the shell and see how far the water drops...
Re: Cover or Leak
