Author Topic: 110 volt or 220  (Read 5387 times)
tuffy
110 volt or 220
« on: June 22, 2011, 08:53:23 pm »
I have an indoor 2 person tub that is wired for 110  with 22 jets.  The jets do not have enough pressure to suit me  would it improve the pressure if I changed it to 220
110 volt or 220
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: 110 volt or 220
« Reply #1 on: June 23, 2011, 08:01:04 am »
No, it would only heat up faster.
sorebikr
Re: 110 volt or 220
« Reply #2 on: June 23, 2011, 11:29:07 am »
That's assuming its capable of handling a 220v hookup.  :)  Otherwise it'll lead to something else entirely.
ejf The Spa Guy
  • THE SPA GUY
Re: 110 volt or 220
« Reply #3 on: June 23, 2011, 12:02:31 pm »
Really the only thing your gaining is the increase in heater size, allowing the heater to work well the spa is on high speed, The pressure will not change, you should be able to close of some jets to increase the jet pressure ...
VTXMAN
Re: 110 volt or 220
« Reply #4 on: June 23, 2011, 07:15:28 pm »
If you switched to 240V you could change the pump and that will help but you need to check with the manufacturer and see if that is even possible.
Waterbug
Re: 110 volt or 220
« Reply #5 on: June 27, 2011, 10:12:38 pm »
  If your tub is 120/240 convertable, all you gain is the ability to run the pump at high speed, while heating.  If it isn't convertable, you may need to replace both the pump and heater.  You would also need to replace the breaker on your main electrical panel , the GFI circuit disconnect and the wiring from the main panel to the tub.
Jet Sitter
Re: 110 volt or 220
« Reply #6 on: June 28, 2011, 01:23:36 am »
Tuffy - Try turning off the jets that are not located where you are seated.
Waterbug
Re: 110 volt or 220
« Reply #7 on: June 28, 2011, 09:12:07 pm »
  Tuffy, you may not have to convert from 120 VAC to 240 VAC, to install a higher capacity pump.  Although, any higher capacity pump is going to draw more power/current and  probably require rewiring and new breakers.  240 VAC equiptment applies a more even draw on your electrical service and is therefore cheaper to run.
Re: 110 volt or 220
