Author Topic: Hot Tub Flex Hose Leak  (Read 4958 times)
dmac37
« on: June 11, 2011, 06:29:37 pm »
My heater went out over the winter, I drained the tub undid my pump connections but must of still had some water and a frozen pipe leak. I replaced the heater and found the leak (I hope the only one :)) there is about a 3" long split on a flex pipe that sits at the very bottom of the tub floor.
Im thinking the best way to repair this is to cut the bad section out and pvc glue a coupling to join the hose? Would a barb coupling and clamps be too weak for the pressure? Is there a better way to repair this?
Thanks in advance!
VTXMAN
Re: Hot Tub Flex Hose Leak
« Reply #1 on: June 15, 2011, 04:15:31 pm »
What type of hose split, if just PVC cut it out and couple in a new section.
« Last Edit: June 16, 2011, 04:39:56 pm by VTXMAN »
ejf The Spa Guy
  • THE SPA GUY
« Reply #2 on: June 16, 2011, 12:33:17 pm »
thats what i would do. cut it out and glue in new couplers...
