Author Topic: J-345- No bubbles coming out of the heater outlet  (Read 3057 times)
gdal
« on: May 27, 2011, 06:14:21 pm »
Like the title says ... I noticed that my heater outlet is not producing bubbles since I removed a defective ozone check valve (leaking) from my plumbing system.  I don't have an ozonator, but the spa had this valve installed and it was leaking bad.
The heater works fine and there's hot water coming out of the outlet, but no bubbles.  I just had an FL1 error that I just cleared a few days ago.
Any help is greatly appreciated.
ndabunka
Re: J-345- No bubbles coming out of the heater outlet
« Reply #1 on: May 28, 2011, 10:00:34 pm »
Others here can correct me but if you don't have an ozonator, you would not have any way of making the "bubbles" so this current condition seems right if their is no ozonator in the line.
Rogert
« Reply #2 on: May 30, 2011, 05:44:42 pm »
By plugging the ozone line you have stopped the air getting into the ozone injector .And if you are not running an ozone then there is no need for the air .So your tub is working correctly!
