Author Topic: Emerald Spa temp control problems  (Read 2923 times)
pjjp21
  • We Love our Emerald!!
« on: May 14, 2011, 11:18:26 am »
i have an Emerald spa that is about 6 years old.  i set the temp of the water at 95 degrees when it is not being used.. after i set the temp i ck it 2 or 3 days later and the water temp is set at 104 degrees.... any ideas what could be causing this?
thanks,  John
soak-king
    • Backyard Oasis
Re: Emerald Spa temp control problems
« Reply #1 on: May 14, 2011, 02:55:43 pm »
Is the spa sitting in direct sunlight for a good portion of the day?
« Reply #2 on: May 14, 2011, 05:51:22 pm »
 Plus one on the sun thing, is the temp set at 95 but the water temp reads 104 and does the water feel like it's 104?
pjjp21
« Reply #3 on: May 15, 2011, 09:51:00 am »
the temp of the water is 104...but the setting on the Topside control also is at 104.  it changes from the 95 degree  setting to 104..the max setting, by itself!...spooky
