Author Topic: unlevel tub  (Read 3783 times)
sstrahan7@msn.com
unlevel tub
« on: April 16, 2011, 08:57:09 am »
Any suggestions/idea's/advice on how to level out an uneven hot tub. It was placed on a existing concrete pad, which now appears annoyingly unlevel. I read you should not just shimmy one side, that it needs more support than this. If I do decide to just live with it, will it cause any damage to the tub over the long term? I'm guessing it is about 1-1 1/2" uneven. It is a Sundance Cameo, if it makes any difference.
unlevel tub
colo_artist
Re: unlevel tub
« Reply #1 on: April 16, 2011, 05:41:58 pm »
You could check out mudjacking.
I had an uneven sidewalk and an overly sloping concrete pad for the front porch mudjacked. They drilled some holes and pumped in a liquid slurry to push the low parts up. The pump was controlled by a hand held unit and it was easy to make fine adjustments.
Odds are good they'd be able to do it without having to remove the spa.
Re: unlevel tub
