Author Topic: vacation chemicals  (Read 2675 times)
abarts
vacation chemicals
« on: January 28, 2011, 03:51:14 pm »
We will not be using the tub for 15 days, what do you suggest to keep it chemically close so when we get back we do not lose the water.
vacation chemicals
Re: vacation chemicals
« Reply #1 on: February 01, 2011, 08:13:07 am »
What are you using now, Chlorine or Bromine? I generally suggest you turn the temp down while you are gone, hot water goes bad much faster than cooler water.
soaknit
« Reply #2 on: February 01, 2011, 12:14:19 pm »
chlorine with ozone and frog.
« Reply #3 on: February 01, 2011, 01:28:39 pm »
Whether its bromine or chlorine, either way I'd add a couple tablespoons of granular chlroine, lower the temp and when you get back it should be in good shape.
paulsimmons
« Reply #4 on: February 03, 2011, 05:09:01 pm »
I second the message about granular chlorine and lowering the temp.  That should be good to hold it while you're away.  You might have to rebalance a bit when you get back but it shouldn't be anything major and it would likely depend on how picky you are on the water    ;D
