Author Topic: marquis spa temp  (Read 5178 times)
bcrobbins
marquis spa temp
« on: December 15, 2010, 07:01:58 pm »
Just got a marquis spirit ls spa when I set it at the highest temp (104) its not hot enough for me is their something  to change to make it go hotter my old tub I set at 106.Tub is 2or 3 years old but new as it was setting on the dealers floor.Thanks
marquis spa temp
ejf The Spa Guy
  • THE SPA GUY
Re: marquis spa temp
« Reply #1 on: December 16, 2010, 12:14:35 pm »
the temps are all set for a max of 104 degrees now....
« Reply #2 on: December 17, 2010, 12:07:53 am »
Hot Spring go to 106.  There may be something dealer can do to reset/bypass max temp.
stuart
« Reply #3 on: December 20, 2010, 02:13:41 pm »
bc,
My best guess is that you're running that on 110v in which case you're dealing with a smaller body of water that shuts the heater off when you turn the jets on high. This being the case your cooling the water with the jets and with your body temp taking up a large amount of the volume.
I suggest running 220...If you're on 220 and still dropping below 103 when you turn the jets on then you might have the pin for 30/50 amp set wrong...
