Author Topic: Optima waterfall lights do not work-what to do?  (Read 7080 times)
sandbag3
« on: November 27, 2010, 01:13:21 pm »
I have a Sundance Optima tub and there are two tub lights. The main underwater light works but the led lights under the waterfall does not. Does anyone know how to fix the waterfall lights? Everything else is working fine?
Thanks ???
Bonibelle
  • '05 Marquis Epic
Re: Optima waterfall lights do not work-what to do?
« Reply #1 on: November 28, 2010, 05:08:43 pm »
I had a problem with the light below the waterfall in my original Epic. The dealer had to come dig foam out from the back of the tub to get to that light and replace the led. I guess the same thing would have to happen for your tub. I believe Marquis had a lot of problems with that waterfall light, perhaps because it got very hot from the foam and tub temperatures. My replacement Epic ('08) did not have that light under the waterfall, so I guess they decided to eliminate it.
Probably your best bet would be to call your dealer.
ndabunka
« Reply #2 on: December 02, 2010, 02:30:15 am »
Thanks ???
Sundance and Jacuzzi are the same company and may have used the same components for their waterfall lighting systems.  I have a 2003 model Jacuzzi J370 (two waterfalls both with lights built into them).  One failed a while back while it was still under warranty and the dealer came out and replaced both of them at no cost.  In my case they did NOT have to dig out any foam.  They were able to gain access from the waterfall itself.  You may want to ask Jacuzzi dealers here what they know about your issue.
