Author Topic: emptying/refilling the tub  (Read 4983 times)
buymybook
« on: November 15, 2010, 02:29:48 pm »
ok, we bought a Caldera Cantebria in September, and I planned to empty/refill it in early December, hoping the weather will cooperate.
quick question-do i need to flip the breaker and turn the whole thing off when I do this? I am thinking if it stays on the filter will be just sucking in air and that might cause a problem.
thanks
Re: emptying/refilling the tub
« Reply #1 on: November 15, 2010, 02:38:59 pm »
SHUT the power off. Leaving  it on could cause costly, unwarranted damage.
buymybook
« Reply #2 on: November 15, 2010, 02:42:46 pm »
thanks for your quick reply!
soak-king
    • Backyard Oasis
« Reply #3 on: November 15, 2010, 02:56:07 pm »
+1  :)
BNMac
« Reply #4 on: November 16, 2010, 03:40:21 pm »
This is an excellent time to test your GFI as well.  When I kill the power to our tub, I don't flip the breaker, I push the Test button.  The breaker flips down halfway indicating a trip condition, and the power is off at that point.  To reset the breaker, turn it completely off, then when you have nearly filled the tub, you can turn it on.
I always test it when I swap filters, perhaps 1-3 weeks apart.
rick
« Reply #5 on: November 16, 2010, 06:41:18 pm »
I used to do total empty/refills but have found it easier to just open the drain and add new water while it is draining.  I'll do this for about an hour maybe less, and while it's not a total water change,  I do get crystal clear water again, and I don't have to spend as much time heating it back up.
« Reply #6 on: November 17, 2010, 12:14:53 am »
I've never heard of anyone doing that? ??? Seems like a waste to me and I guess I don't really see a huge advantage. Other than testing for TDS, you would never really know when you've made a significant difference...
« Reply #7 on: November 17, 2010, 10:49:06 am »
Thats not too uncommon in the dead of winter out on the tundra where its friggin freezing cold and you just want to freshen the water. Otherwise, I'd opt for a full drain/refill every time.
« Reply #8 on: November 17, 2010, 11:23:33 am »
Perhaps for some, the tundra is so friggin freezing cold, they have a slight.....impairment (?) .... which impacts their judgment and memory.
« Reply #9 on: November 17, 2010, 02:12:09 pm »
Nice to see you guys too!  :P  :D
« Reply #10 on: November 17, 2010, 04:47:10 pm »
You're like the kid who promises himself he won't work for his dad's business after he gets out of school but eventually he comes back home to after all. Welcome back SteveO
« Reply #11 on: November 17, 2010, 04:59:56 pm »
Quit dissin the tundra!! Try driving across the frozen lake in California drunk! See where that gets ya!!
