Author Topic: water refill  (Read 4483 times)
fridaydog
water refill
« on: November 04, 2010, 09:26:24 am »
When I refill water due to evaporation (5-10 gallons at a time). Do I need to refill using a hose through the filter area like when I do to fill the whole tub up?
In other words can I just pour buckets of water into the tub to add water due to evaporation loss.  It's getting cold here in MN and I will bring my hoses in due to freezing.
water refill
Re: water refill
« Reply #1 on: November 04, 2010, 11:05:36 am »
Pour it on in.  ;)
Vanguard
Re: water refill
« Reply #2 on: November 04, 2010, 11:26:57 am »
When you're just adding water, it really doesn't matter how you add it.
ejf The Spa Guy
  • THE SPA GUY
Re: water refill
« Reply #3 on: November 04, 2010, 02:28:53 pm »
Just as the Vanguard and Jacuzzi Jim said just fillerup.
Re: water refill
« Reply #4 on: November 04, 2010, 03:47:02 pm »
The reason you fill through the filter when the spa is empty is so that you can get the water directly down into the pumps to displace the air inside them and help avoid the issue of air becoming entrapped in the pumps (especially the circ pump).
Therefore, if the spa is already mostly full and you're just "topping" it off there is no need to fill through the filter, just lay it inside the spa anywhere.
fridaydog
Re: water refill
« Reply #5 on: November 04, 2010, 04:50:36 pm »
Thanks guys
Swell-Tub
  • Scott
Re: water refill
« Reply #6 on: November 13, 2010, 04:21:00 am »
Just spill enough beer in the tub when you are sitting in it to make up for he lost water. It can act like anti-freeze for your tub.  ;D
2008 Jacuzzi J-470
Re: water refill
