Author Topic: 2010 marquis vs 2010 hot spring vs 2010 jacuzzi  (Read 3522 times)
abarts
« on: October 11, 2010, 01:23:35 pm »
I am looking now at 2010 model Vanguard vs J365 vs Marqui Euphoria.
What is the general consensus on quality, & support? I have wet tested J-365 so far. Will test Hot Springs next, then Marquis. I have done research on Jacuzzi and Hot Springs, but not much on Marquis. I just found out we have a Marquis dealer here, so I will make a visit there next, though they do not have many in stock now.
Anyone have some first hand experience or advice, I would like to here from you. Buying this winter.......
Jet Sitter
Re: 2010 marquis vs 2010 hot spring vs 2010 jacuzzi
« Reply #1 on: October 11, 2010, 02:16:49 pm »
I have wet tested all three (pre-2010 versions) and suggest you do the same.  Each is a quality spa - you cannot make a "wrong" choice.  Which tub is the best fit for the primary user(s)?  Which dealer do you have most confidence in?  They may be about equal.  How does the price compare?  For what it's worth my favorite of the three is the J-365 (best fit for us) - others likely have a different preference.
abarts
« Reply #2 on: October 11, 2010, 08:53:44 pm »
Thanks for the info.
ejf The Spa Guy
  • THE SPA GUY
« Reply #3 on: October 13, 2010, 08:52:00 pm »
all 3 a very good spa brands and great backing, they are all bout the same siza, the Hot Springs and the Jacuzzi use 24/7 circ pumps, more constant clean, were the Marquis uses the main pump low speed to filter 2 hours every 12, they use the in line spa frog system, i personnally have sold the inline frog system on my spas i do not like the bromine system it uses. all have great warranties. the questions you have to ask yourself is the comfort, easy to operate and maintain and knowing the total costs of wach on chemical maintenance in a year. and the comfort level you have with the dealers you are dealing with.....
