Author Topic: Anyone order a Sundance Optima cover from rhtubs.com?  (Read 3651 times)
pg_rider
  • I've been Optima-ized
« on: August 09, 2010, 02:21:51 pm »
Blatant laziness here -- I need a cover for my 2006 Sundance Optima and want to get one from rhtubs.com.  However, there are a number of measurements they need in order to process the order.  Rather than spending a half-hour in the hot sun with my tape measure, I thought I'd see if anyone happens to have the measurements on hand.
Paul G.
ndabunka
Re: Anyone order a Sundance Optima cover from rhtubs.com?
« Reply #1 on: August 09, 2010, 04:37:23 pm »
I ordered one for my 2003 J-370 and the dimensions should be pretty close but I had concerns about the radius so I called them directly and they already had a J370 on file.  With the popularity of that model, they probably already have the dimensions.
pg_rider
« Reply #2 on: August 10, 2010, 01:04:41 pm »
Thanks for the reply!  I actually emailed them before I posted and they told me they didn't have any measurements on file that would guarantee a proper fit....   ???
Paul G.
« Reply #3 on: August 10, 2010, 01:18:16 pm »
I'm guessing they don't want the responsibility to keep track of changes in each model year or for any options that might cause this to vary (speakers?)  Its not really hard to do and there is enough play in the dimensions that you should come up with a proper fitting cover easily.
