Author Topic: Hot Spring Sovereign Model I Jumper Settings for 115V  (Read 4025 times)
wakeylad
« on: July 19, 2010, 04:14:41 pm »
Hi:
I just purchased a used Sovereign Hot Tub (Serial# I3C1138). It was converted to 230V. I need to convert it back to 115V. I checked the manual and it shows the wiring prior to the 230V conversion but not the jumper settings.
Does anyone know what the 115V jump settings are? Also, just to be safe, if you have the wiring diagram for 115V, that would be helpful.
The previous owner didn't have the original 115V cable (with the Ground Fault Plug) that came with the Hot Tub. Would anyone know the part# and approximate cost for a replacement?
Thanks in advance for all your help.
