Author Topic: Hear relays click but motors won't start  (Read 18605 times)
NorthernGirl
« on: May 25, 2010, 09:52:22 am »
Coast mountain hot tub
Cyprus model 2003
Everything is wired up properly with 3 wire to the GFI per mark in cabinet
Control board will power up, it senses and shows the temp of the water and you can adjust the temp
When I push start for recirculating panel and jets to run you can hear relays clicking on  but neither motor starts.
I check 3 fuses on board and all test okay
Any suggestions ?
Re: Hear relays click but motors won't start
« Reply #1 on: May 25, 2010, 10:56:45 am »
Has it ever worked properly at it's current location?
VTXMAN
« Reply #2 on: May 25, 2010, 02:36:11 pm »
Only a voltmeter can tell you what is happening, either the spa is not getting proper voltage, the board may not be suppling voltage to the pump, the pump is getting voltage so it is bad or there is a connection issue between the pump and board.
My guess is the spa is not getting 240V.
NorthernGirl
« Reply #3 on: May 25, 2010, 09:13:33 pm »
success. turned out the main breaker was not bridging the buss bars for 220v. was only getting 110. thanks for the help.
