Author Topic: Hot tubs and dust  (Read 3468 times)
momof1
Hot tubs and dust
« on: May 24, 2010, 03:06:27 am »
I am researching hot tubs (small 2-3 person) and have not come across an answer to my question so hope someone can help. I live in the country on gravel roads and can be very dusty. I plan on putting the hot tub on a deck on the back of the house. Will the dust be a problem or will it cause more maintence and upkeep and problems to the tub? Thanks for any help.
Hot tubs and dust
Re: Hot tubs and dust
« Reply #1 on: May 24, 2010, 07:49:59 am »
Welcome to the forum.
I would think the only dust problem will be on the cover. It will be running the majority of its hours with the cover on.  Some of our service techs may have some insight.
« Reply #2 on: May 24, 2010, 11:16:43 am »
The dust won't be a problem. The spa will be covered for 23½ hours per day and even though the cabinets are built to allow some air transfer the dust wouldn't be a problem unless maybe you have huge duststorms like in the Grapes of Wrath.
If you're putting this spa on a deck I persoanlly think a spa that uses a 24 hour circ pump for filtering is best in this application for quiet operation. Spas that use the main pump for filtering can be a bit loud when on a raised deck in my experience unless of course you're very rural and the deck is set off from both your house and neighbors.
momof1
« Reply #3 on: May 24, 2010, 09:15:58 pm »
Thank you both for your reply and helpful information. I guess I can stop worrying about the dust and continue my research. by the way you all are so very helpful and  I have learned so much from your posts. Thanks again!
ejf The Spa Guy
  • THE SPA GUY
« Reply #4 on: May 26, 2010, 12:13:28 pm »
I would agree with spatech, dust should not be a problem with the spa, mainly dirty cover may have to clean it more often, but also being on a deck look into a spa with a 24 hour circ pump, help with noise and vibration when your are not in the spa,,,,
