Author Topic: Hot Spring vs Hot Spot  (Read 31314 times)
honeypot
« on: April 07, 2010, 04:49:39 am »
Hello.
I am looking at the Tempo Hot Spot or the Vista or Envoy Hot Spring.  I wet tested the Tempo and the Vista/Vanguard/Sovereign this past Saturday and liked the Vista.  I felt the Vista may be a little large so I am going to wet test the Envoy this weekend.
Of course the price of the Hot Spot is something I like vs the Hot Spring tubs.   However, I'm not sure that I will be getting the same quality and performance from the Hot Spot.  I also like the idea of the Salt Water Cleaning system (ACE) that is only available in the Hot Spring tubs (for an extra G).  I wonder if that is worth it?
All experienced hot tubbers please help me with this decision.  I like the dealer and he is not trying to push either on me..,. he simply states the differences.  One big difference I see is the warranty (2 years vs 5 years).   Wonder if hot tubs malfunction in that short of time frame?  Or maybe I should consider that to be related to the overall craftmanship.
Hope to get some responses to help in my decision. ::)
Water Boy
Re: Hot Spring vs Hot Spot
« Reply #1 on: April 07, 2010, 08:31:38 am »
I could be wrong as I am not a HS dealer, but I am pretty sure that the Hot Spot line has a one year warranty, and not a two year like you had mentioned. Again, I could be wrong as that may have changed as well. But, just a few weeks back a HS dealer said that the warranty didnt change, and if that is the case, it is a one year warranty. Just a FYI.
« Reply #2 on: April 07, 2010, 08:34:23 am »
Welcome to the forum,
I recently went with my sister while she looked at the same tubs.  She also looked at one of the Limelight spas and chose between the limelight and a Vanguard and ended up with the Vanguard.  Unrelated, my non-HS tub had a couple of problems in the first 2 years and then has been fine since. Good luck, there will be tradeoffs either way, go with the one you are comfortable in.  I'll let others answer the salt system question.
« Reply #3 on: April 07, 2010, 08:38:28 am »
Could it be the dealer is offering a 2nd year on his own?
« Reply #4 on: April 07, 2010, 10:01:52 am »
I am a Hot Spring/Hot Spot dealer.  Hot Spot warranty is 2 years.  Although it is a shorter warranty, standards are the same.  Multiple testing.  We have found, because they are a little simpler, the Hot Spot line is relatively trouble free.  Warranty has a cost, so, if the Hot Spots had the same warranty as the Hot Spring, price would go up.
Water Boy
« Reply #5 on: April 07, 2010, 10:04:45 am »
Oops, I was wrong. :-X Thanks for the clarification Dan!
I guess this is why I was wrong. When I type in "Hot Spot Spas Warranty," this was the first page that pullled up for me. I guess they need to update their website!! ;)
http://www.ohiopools.com/hot-spot-warranty.html
« Last Edit: April 07, 2010, 10:52:31 am by Beer Man »
« Reply #6 on: April 07, 2010, 11:21:14 am »
Warranties are NOT free, they are included in the price. Length of warranty should never be equated directly to quality; I've seen poor quality spas with long warranties and good quality spas with short warranties. What Watkins has done is create a Hot Spot spa for people unable/unwilling to purchase their premium Hot Spring spa line. The fact that one has a shorter warranty is simply a way to bring the cost down because if they had given it the 5 year warranty they would have had to charge more for the product.
Compare the features, length of warranty, price, how well each fits you, the jets, the look, the size, the layout… and decide which on you truly want understanding that whichever you get will be in your back yard for the next decade+.
Vanguard
« Reply #7 on: April 07, 2010, 10:25:50 pm »
Here is the link the the Hot Spot warranty:
http://www.hotspothottubs.com/pdfs/warranty.pdf
honeypot
« Reply #8 on: April 07, 2010, 10:40:46 pm »
It seems that most of the comments have focused on the warranty... how about the continuous pumping that the Hot Spring has and the Hot Spot doesn't (i.e., is it a big disadvantage to circulate the water twice a day vs the continuous pump).  How about the salt water treatment that is available in the Hot Spring, but not the Hot Spot.  That is something that is really interesting to me as far as ease in maintenance of the water and dryness of the skin.  What are 'your' feelings?  Is it worth it?
This decision is made so difficult because of the price difference between the two.  I am looking at a dealer who is offering the Tempo at 5,995 and the Envoy at 10,995 (without the salt water purification system... that would be an addition 1,000).  This price includes everything except the electrical work.  Good prices?
Some more information from experienced hot tubbers would be so appreciated.  I'm getting anxious.   :-\  Thanks a bunch.  honeypot
Vanguard
« Reply #9 on: April 07, 2010, 11:14:05 pm »
I personally like having the 24 hour pump.  I just like the fact that the water is always circulating.  The cost to do that is very little.  If I had a swimming pool and could circulate the pool all the time, I would, but the cost to do that is prohibitive.  However, the Hot Spots as do other brands of spas without 24 hour circulation still have more than adequate circulation to keep your water clean, clear and hot.  There are no big drawbacks to not having a 24 hour pump.  The main key is to get the water to turn over a certain number of times a day.  Both methods get you there.
The ACE system is still so new that it is hard to comment on.  Most people like salt because the water feels "softer."  That is one of the reasons salt systems have become so popular with pools.  Salt systems on pools tend to cause a lot of corrosion of metal products as well as degradation of natural stone products around the pool.  From what I've seen so far with the ACE system, they are doing things differently.  But again, the system is so new that it is hard to say if the $1,000 system is "worth it."  I think the worth is up to the consumer.
There is a big difference in price and I can see where that could make it difficult.  Wet testing should tell you a lot.  The Envoy is a great spa.  One of my favorites.  I would seriously consider it for my next hot tub.  However, my wife is only 5'2" and she refuses to wet test so I'm wary of getting an Envoy for myself.  I'm worried it will be too deep for her.
Some of the things to consider if you want that add cost to a Hot Spring are things like the control panel.  There is a huge difference between the two.  The Hot Spring has a lot more functionality than the Hot Spot.  The water fall on the Hot Spring is different and more expensive.  The Hot Spring is full foamed with different layers of different densities of foam.  The Hot Spot is full foam, but the method is different.  I believe the method for the Hot Spot is less costly.  The warranty as has been mentioned is three years longer.  That costs more.
If you feel like you can absolutely live without all those things, then go with the Hot Spot.  I know how I am.  I want the "stuff."  I'm looking at cars right now.  I'm all but ruling out cars that require me to put a key in the ignition.  My current car has that and I really like it.  So now I don't want to do without it.  I can't buy a Camry LE because it doesn't have the "stuff" I like in it.  I would buy a Camry XLE because it does have the stuff I like.  Nearly identical cars, same quality (current issues aside), same size, etc.  But I would pay more for it just because I like it better.
Either way you're going to have a good spa.  They will both last a long time.  I would try to negotiate a little on the prices to see if you can do better.  Be prepared to walk if they don't negotiate with you.  Leave it with them that if they can find a way to do better that they can call you.  Once you feel like they aren't going to go down anymore, then go ahead and make your deal.
Good luck with this.  I hope I've answered more of your questions.
honeypot
« Reply #10 on: April 08, 2010, 08:27:16 am »
Thank you, Vanguard and everyone for your comments.
I have had some hesitation regarding the ACE as it is so new.  For years and years people have enjoyed hot tubs without the need for a salt water system.
I have wet tested the Tempo, Vista, Vanguard.  I am to test the Envoy this Friday.  I was really focused on the Hot Spring line up and didn't give the Tempo the attention I should have.  After much thought later about the 6 grand price difference I now think I should give the Tempo another wet test.
I did love the water fall on the Vista and all the gadgets.  However, would I rather still have 6,000 in my pocket?
Still not clear on where they come up with twice the cost of the Tempo... seems outrageous.  It's like comparing apples and oranges because of the price difference... makes me wonder if the Hot Spot is junk or something.  Maybe that's the idea?
I am 6 feet tall so a small tub would never do for me.
One other thing, how are the spas in the summer months... I'm hoping they are cool enough to enjoy on a hot summer day.  I understand that they only get down to 80.  Any experience with using it to cool off after a hard day of yardwork, golf, etc.?
As far as the price goes, the dealer said that was his bottom price... does it seem too high?  I should push him more, eh?
Thanks everyone!
Pam
Vanguard
« Reply #11 on: April 08, 2010, 11:53:37 am »
The Hot Spots are not junk.  They build the same quality into Hot Spot as all their other spas.
Other than some of the extra stuff and warranty, Watkins also sells the lower end spas with a lower margin.  The dealers tend to that as well.  The margins on the premium spas are higher.  That is the way most products are sold.
Hot Spot was designed to be a price point spa to help those that didn't want to pay the big bucks still get into a high quality spa.  Hot Spot is a completely different spa than it was when it was first introduced.
Regarding summer, I've always kept my spa hot in the summer because I still like the hydrotherapy that time of year as well.  Even with the heat outside, I've still found that I enjoy the hot water to sooth my muscles and relax at the end of the day.
To keep a spa cooler in the summer, you have to turn down the temperature and keep the cover cracked open.  Otherwise, you really won't lose much heat.  Especially with spas with a 24 hour pump.  Hot Spring and others use some of the heat from the circ pump to heat the water to utilize more of the energy and not waste it.
honeypot
« Reply #12 on: April 08, 2010, 01:21:16 pm »
Vanguard,
You are really helping me see the light.  My comment about "junk" was that perhaps the price difference was a sales ploy to make a consumer think so... (i.e., you get what you pay for and if this spa is thousands of dollars cheaper than a Hot Spring maybe there is a reason...).
I'm not clear on what you mean by "lower margin" or "margins" in general.  Perhaps you could explain that for me.
I haven't been on these forums long.   Is your name Vanguard because that is the spa you have?  Are you involved in the sales of hot tubs as I see some on this forum are?
I am really glad to have a knowledgeable person giving me feedback.
BTW, I have asked the dealer to turn the temp down all the way on the Envoy so I can see what it feels like.  When I get in spas be it in the winter or summer, I do not like them real hot.  It makes me feel uncomfortable.
Thanks so much.
Pam
« Reply #13 on: April 08, 2010, 01:28:02 pm »
Thanks so much.
Pam
I imagine most dealers keep the temp at about 101º but there is a big difference in feel between 99º and 101º so you don't need it lowered much to feel a difference. Unless it is very hot outside in the summer when some people use it as a cold spa most people will not go lower than 98 or 99º the other 10 months which is about body temp so I'd have them lower it to 99º if higher temps are not your thing (not mine either, wife likes 102º and I like 100º).
honeypot
« Reply #14 on: April 08, 2010, 01:38:32 pm »
 :D Spatech_tuo ... is that from Mr. Mom?  220, 221... A funny movie!  :D
